[GRASS5] xganim - only white output
Glynn Clements
glynn.clements at virgin.net
Mon Jan 28 08:56:19 EST 2002
Markus Neteler wrote:
> the "xganim" (note the "g") is a nice tool to visualize
> time series. Until recently it worked well. However,
> since the merge the head version which is obviously
> identical to that in release branch only produces
> white colors. Looking at the same map(s) with d.rast,
> everything is fine. It's quite strange.
> Does anyone have the same experience?
Well, I don't see any problem[1] with the release version, and "diff"
says that the head version should be identical.
[1] with a very brief test: "xganim view1=elevation.dem".
The change history over the past year is:
date: 2001/06/12 07:51:59; author: markus; state: Exp; lines: +0 -0
readded as forgotten for release_branch
date: 2001/10/16 18:12:22; author: glynn; state: Exp; lines: +2 -2
Add configure tests for Motif
Remove unused variables from head.in
Remove references to XINCPATH from various Gmakefiles
date: 2001/10/17 08:47:15; author: markus; state: Exp; lines: +8 -9
fixed some compiler warnings
date: 2001/10/19 13:17:20; author: glynn; state: Exp; lines: +61 -186
Support visuals other than 8-bit PseudoColor
date: 2002/01/22 04:51:42; author: glynn; state: Exp; lines: +66 -192
Merge releasebranch_11_april_2001_5_0_0 with HEAD
date: 2002/01/22 23:04:54; author: glynn; state: dead; lines: +0 -0
Removed src.contrib/GMSL/xganim/main.c.org
The most substantial of these changes was 2001/10/19; this added
Clr_table.c (from XDRIVER), and changed the drawing code to use it.
Glynn Clements <glynn.clements at virgin.net>
