[GRASS5] New GIS & GRASS5 user with many questions...
Samizdatt
Samizdatt at earthlink.net
Tue Jan 29 18:24:22 EST 2002
GRASS5 is compiled, and appears to run, but are there any sample data sets I can use to test and familiarize myself with GRASS5?
********** Output from testgrass.sh **********
org:/install/grass5.0.0pre3 # ./testgrass.sh
testing in UTM projection environment:
projection: 1 (UTM)
zone: 13
datum: ** unknown (default: WGS84) **
ellipsoid: ** unknown (default: WGS84) **
north: 4928000
south: 4914000
west: 590000
east: 609000
nsres: 50
ewres: 50
rows: 280
cols: 380
Test the -129 r.mapcalc bug:
EXECUTING testmap = ... 100%
CREATING SUPPORT FILES FOR testmap
range: -129 -129
r.mapcalc bug test o.k.
Tests finished.
My goal is to display county level data sets, currently in FIPS codes, onto a map of the US, and individual states. I'd like to deliver the images via webserver to clients using a browser. As I perused the programming manual, I noticed that there are limitations to html's ability to render clickable points, which I can work through later, but I'd like to know if I'm on the right track in using GIS & GRASS5. Also, any links, hints or info anyone can provide to additional information would be greatly appreciated.
Thanks!
