[GRASS5] New GIS & GRASS5 user with many questions...
Samizdatt
Samizdatt at earthlink.net
Wed Jan 30 11:52:14 EST 2002
Thanks Markus!
The adventure begins...
Markus Neteler wrote:
> Hi Samizdatt,
> the ./testgrass.sh is only intented to test GRASS on a system level.
> You may want to use
> Spearfish sample data,
> have a look at:
> http://grass.itc.it/data.html
> GRASS 5.x: SPEARFISH dataset (9.6MB size)
> + " SPEARFISH dataset related documents: "
> Enjoy,
> Markus Neteler
> On Tue, Jan 29, 2002 at 04:24:22PM -0700, Samizdatt wrote:
> > GRASS5 is compiled, and appears to run, but are there any sample data sets I can use to test and familiarize myself with GRASS5?
> > ********** Output from testgrass.sh **********
> > org:/install/grass5.0.0pre3 # ./testgrass.sh
> > testing in UTM projection environment:
> > projection: 1 (UTM)
> > zone: 13
> > datum: ** unknown (default: WGS84) **
> > ellipsoid: ** unknown (default: WGS84) **
> > north: 4928000
> > south: 4914000
> > west: 590000
> > east: 609000
> > nsres: 50
> > ewres: 50
> > rows: 280
> > cols: 380
> > Test the -129 r.mapcalc bug:
> > EXECUTING testmap = ... 100%
> > CREATING SUPPORT FILES FOR testmap
> > range: -129 -129
> > r.mapcalc bug test o.k.
> > Tests finished.
> > My goal is to display county level data sets, currently in FIPS codes, onto a map of the US, and individual states. I'd like to deliver the images via webserver to clients using a browser. As I perused the programming manual, I noticed that there are limitations to html's ability to render clickable points, which I can work through later, but I'd like to know if I'm on the right track in using GIS & GRASS5. Also, any links, hints or info anyone can provide to additional information would be greatly appreciated.
> > Thanks!
> > grass5 mailing list
> > grass5 at grass.itc.it
> > http://grass.itc.it/mailman/listinfo/grass5
> grass5 mailing list
