[GRASS5] Critical bugs for Release?
Glynn Clements glynn.clements at virgin.net
Tue Jul 16 12:26:43 EDT 2002
Bernhard Reiter wrote:
> As grass5.0.pre5 was release about the 25th last month,
> we shall prepare for the 5.0.0 release and try to see if there
> are release critical bugs and do one of the following:
> 	+ release 5.0.0
> 	+ do another 5.0.0pre6
> 	+ discontinue the release branch for some development
> 	regarding non critical bugs.
> Again: Please fix only release critical bugs on the release branch.
> I've counted 38 bugs in the bug-tracker right now.
> (5 do not have an area assigned yet.)
> No bug has been marked as being critical.
> 7 bugs have a priority of 70, they might be critical.
Here is a summary:
#840	Re: r.reclass NULL
This is a (priority 70) wish. Unless it's killed on the grounds of
being a bad idea, it should probably have its priority lowered.
#1034	r.in.tiff segfaults
Eric reported that this should now be fixed.
#1052	[rsv].proj are crashing
This spawned a long thread, reaching the conclusion that it should now
be fixed. BTW, was m.proj ever fixed?
#1092	v.digit menu broken ?
Markus reported that this was due to synchronisation with d.zoom.
Can someone who is familiar with v.digit should comment on whether the
existing behaviour should be changed?
#1101	GUI (tcltk) does not run
MacOS X. The reporter subsequently replied that there was a problem
with his Tcl/Tk installation.
Maybe we should add a note that, for "hybrid" platforms such as Cygwin
and MacOS X, Tcl/Tk must be the Unix/X11 version, not a
Windows/Cygwin/MacOS version.
#1127	Subject crash on startup unless Init.sh hand-modified
This was due to a shared library misconfiguration. Closed.
#1136	detailed view of vector maps doesn't work
The reporter followed up with "v.spag then v.support seem to fix
this", so presumably this should be closed?
#1170	m.in.e00 segmentation faults
No idea.
Glynn Clements <glynn.clements at virgin.net>
