[GRASS5] Initial window state
Radim Blazek
blazek at itc.it
Fri Jul 19 03:41:23 EDT 2002
On Friday 19 July 2002 01:02 am, Roger Miller wrote:
> I get blank screen behavior in a number of different ways, but that
> behavior is a fairly minor problem to an experienced user. I think the
> main case where the blank screen result is a problem is when a new user is
> forced to set the map region when they first start GRASS. Most people
> probably don't know the area they need to cover and they don't have any
> basis for understanding the significance of the initial region settings.
> Often the user's initial window settings are incorrect or just useless and
> the first map they try to display produces a blank screen. When that
> happens GRASS looks broken; in fact one could say that GRASS *is* broken
> because it lets that happen.
What about warning:
> d.rast map=x
WARNING: Map 'x' is outside the current region, try 'g.region rast=x'
Radim
