[GRASS5] Initial window state
Moritz Lennert lennert.moritz at edpnet.be
Sun Jul 21 08:19:37 EDT 2002
On Fri, Jul 19, 2002 at 05:29:24AM -0600, Roger Miller wrote:
> On Friday 19 July 2002 01:41, Radim Blazek wrote:
> > What about warning:
> > > d.rast map=x
> > WARNING: Map 'x' is outside the current region, try 'g.region rast=x'
> Radim,
> I think that's at least a step in the right direction and probably a good
> addition to d.rast, d.vect.* and d.sites.
> Even though I do like this idea, I would prefer to go the next step.  By
> itself this idea identifies a problem without actually solving it.  Solving
> the problem for the specific case of initialization would require very little
> more work.  In fact, I think that adding just the initialization check might
> take less code and I'm sure it would impose less startup overhead.
> I think users -- new users in particular -- would probably prefer to have
> GRASS fix the problem itself rather than requiring them to perform a second
> command then repeating their first command just to get an image displayed.
As a user, I found GRASS very difficult to get going with, and one of the reasons was the region settings. However, I also found that GRASS was the only program that forced me to think about regions and projections, and I like that. Before, I used ArcView and created maps without ever thinking about the (sometimes quite important) issue of projection. Therefore, I find the way GRASS does things quite important on a pedagogical level, and would find it regrettable if GRASS let the user ignore some of the most fundamental questions in cartography.
But I do sympathize with the idea of not "scaring" new users away. In that sense I like Radim's idea.
Moritz
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20020721/c3b49085/attachment.bin
