[GRASS5] Outstanding issues for the 5.0 stable release
Markus Neteler neteler at itc.it
Thu Jul 25 09:13:43 EDT 2002
Hi developers,
since we are getting closer to the stable release of 5.0
(seems we are approximating it only) we have to take another look at
outstanding issues.
The same as earlier:
On Thu, Jun 27, 2002 at 11:45:51AM +0200, Markus Neteler wrote:
> - m.proj/m.proj2 need to be updated to also perform the Nad/Nad
>   datum transformation. An inconsistency between the projection
>   tools is not acceptable for a stable release.
it is still unchanged, right?
> - r.proj needs a clean-up. The improvements coded by Morten Hulden
>   are partially disabled (region sensivity etc) which is a major
>   drawback. If no general solution is possible, we may introduce
>   optional flags.
What is the status here?
Anything else except the remaining bugs and wishes :-) ?
Markus
