[GRASS5] [rpm spec for grass]
Sergiusz Pawlowicz
ser at it-zone.org
Mon Jun 3 04:21:42 EDT 2002
--->[Quoting Markus Neteler <neteler at itc.it>:]
> On Mon, Jun 03, 2002 at 01:28:01AM +0200, Sergiusz Pawlowicz wrote:
> > --->[Quoting Eric G. Miller <egm2 at jps.net>:]
> > > AFAIK, there aren't any "display" or "import" commands in GRASS. There
> > > are categories of commands that do these things, but none named as
> > > "display" or "import". So, what exactly are you referring to?
> > Sorry for misunderstanding, I mean manual files:
> > /usr/X11R6/man/man1/display.1.gz
> > /usr/X11R6/man/man1/import.1.gz
> > These names are too common, IMO.
> AFAIK, the GRASS man pages go into the GRASS directory, not the general
> man directories. Is this different for RPMs?
We were trying to keep the FHS standard:
http://www.pathname.com/fhs/
It helps in unifying systems.
http://ibiblio.org/ser/ | http://it-zone.org/
_________________________________________________________
tldp.org|gnu.org|hyperreal.info|pld-linux.org|it-zone.org
"The moon is made of green cheese." -- John Heywood
