[GRASS5] [rpm spec for grass]
Glynn Clements
glynn.clements at virgin.net
Mon Jun 3 07:18:49 EDT 2002
Markus Neteler wrote:
> > > AFAIK, there aren't any "display" or "import" commands in GRASS. There
> > > are categories of commands that do these things, but none named as
> > > "display" or "import". So, what exactly are you referring to?
> > Sorry for misunderstanding, I mean manual files:
> > /usr/X11R6/man/man1/display.1.gz
> > /usr/X11R6/man/man1/import.1.gz
> > These names are too common, IMO.
> AFAIK, the GRASS man pages go into the GRASS directory, not the general
> man directories. Is this different for RPMs?
Even if the files live in separate directories, "man display" will
only show one of the files.
Glynn Clements <glynn.clements at virgin.net>
