[GRASS5] problems with cvs
Bernhard Reiter
bernhard at intevation.de
Wed Jun 5 14:12:18 EDT 2002
Moritz:
you should use your read write access now, I would assume. :)
No idea what could be the problem, probably the wrong port
of a firewall in between.
On Wed, Jun 05, 2002 at 05:59:17PM +0200, Moritz Lennert wrote:
> This might be a bit off topic, but I have trouble connecting to
> the Intevation cvs server in anonymous read-only access. Whenever
> I try a cvs update, I get
> cvs [update aborted]: recv() from server intevation.de: Connection
> reset by peer
> I do not have this problem with the 'grassbook' cvs repository on
> the itc server.
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20020605/1545a0fa/attachment.bin
