[GRASS5] GRASS-JNI under Windows NT
Claus Hüttermann huettermann at conterra.de
Fri Jun 7 06:19:31 EDT 2002
I compiled GRASS5 and GRASS.java for Windows successfully. But I see a
strange
behaviour running the sample program "check1".
After the first call to a native method ( in this example it is putenv)
the jvm terminates without an exception.
When I use FORTE I see the message
java.lang.UnsatisfiedLinkError: putenv
        at GRASS.libgis.putenv(Native Method)
        at GRASS.libgis.<init>(libgis.java:153)
        at check1.<init>(check1.java:51)
        at check1.main(check1.java:36)
Exception in thread "main"
Can anybody help me??
Thanks in advance,
-Claus
Wir ziehen um - ab April gilt die neue Firmenanschrift:
con terra GmbH
Martin-Luther-King-Weg 24
48155 Münster
Tel. 0251/7474-500
Fax 0251/7474-100
Type: text/x-vcard
Desc: Card for Claus H?ttermann
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20020607/1d3d3295/huettermann.vcf
