[GRASS5] GRASS 5.0.0stable to be released soonish
Glynn Clements
glynn.clements at virgin.net
Sat Jun 8 17:12:37 EDT 2002
Glynn Clements wrote:
> For the remaining changes, I would appreciate opinions as to which
> should be included in the next release. I'll submit my opinions in a
> follow-up.
I recommend including these:
> Makefile.in
> handling of "locale" subdirectory
> configure
> configure.in
> Darwin iconv check
> Darwin PostgreSQL (-lssl -lcrypto)
> html/html/pngdriver.html
> default background is black
> src/display/devices/PNGdriver/README
> locale/Gmakefile
> process all locales, not $LANG
> mk/Makefile.in
> add "locale" subdirectory to "dirs" target
> src/display/devices/PNGdriver/Graph_Set.c
> Fix GRASS_BACKGROUNDCOLOR processing
> src/display/devices/XDRIVER/XDRIVER24/Graph_Set.c
> add "GRASS" to monitor title (tcltkgrass bug workaround)
> src/libes/edit/edit_cellhd.c
> fix rounding of negative values
> src/libes/gis/env.c
> check for empty string in set_env()
> src/libes/proj/geod.c
> re-order headers to deal with geodesic.h issues
> src/raster/r.in.gdal/main.c
> convert ellipsoid name to lower case (bug #1047)
> src/raster/r.mapcalc3/Gmakefile
> src/raster/r.mapcalc3/mapcalc.l
> fix bug with quoted map names
> src/raster/r.mapcalc3/main.c
> allow expression to be split into multiple arguments
> src/raster/r.mapcalc3/xexp.c
> allow two-argument form
> src/raster/r.proj/cmd/bordwalk.c
> ignore invalid points
> src/raster/r.proj/cmd/main.c
> src/raster/r.proj/cmd/r.proj.h
> tidy
> add -n (nocrop) flag
> move "menu" array from r.proj.h to main.c
> src/sites/s.in.mif/Gmakefile
> fix lex invocation
These are harmless, so may as well be included:
> mk/Makefile.in
> generate more complex "gmake5" script
> mk/mid.mk
> mk/mid.mk.shlib
> add LOCALE definition
> mk/mkmakefiles
> optional directory argument
These are worth considering:
> configure
> configure.in
> readline
> src/CMD/head/head.in
> readline variables
> src/include/config.h.in
> HAVE_READLINE_READLINE_H
> readline support
> src/raster/r.mapcalc3/evaluate.c
> src/raster/r.mapcalc3/map.c
> src/raster/r.mapcalc3/mapcalc.h
> copy cats/colr/hist
> src/libes/gis/reclass.c
> disable reclassed_to warning
Glynn Clements <glynn.clements at virgin.net>
