[GRASS5] GRASS 5.0.0stable to be released soonish
Markus Neteler
neteler at itc.it
Tue Jun 11 10:35:33 EDT 2002
> > For the remaining changes, I would appreciate opinions as to which
> > should be included in the next release. I'll submit my opinions in a
> > follow-up.
> I recommend including these:
> > Makefile.in
> > handling of "locale" subdirectory
yes - important fix.
> > configure
> > configure.in
> > Darwin iconv check
> > Darwin PostgreSQL (-lssl -lcrypto)
yes, as needed for Darwin MACOSX.
> > html/html/pngdriver.html
> > default background is black
ok
> > src/display/devices/PNGdriver/README
ok
> > locale/Gmakefile
> > process all locales, not $LANG
ok
> > mk/Makefile.in
> > add "locale" subdirectory to "dirs" target
important fix
> > src/display/devices/PNGdriver/Graph_Set.c
> > Fix GRASS_BACKGROUNDCOLOR processing
> > src/display/devices/XDRIVER/XDRIVER24/Graph_Set.c
> > add "GRASS" to monitor title (tcltkgrass bug workaround)
no idea above upper two. If you recommend, why not.
> > src/libes/edit/edit_cellhd.c
> > fix rounding of negative values
ok
> > src/libes/gis/env.c
> > check for empty string in set_env()
important
> > src/libes/proj/geod.c
> > re-order headers to deal with geodesic.h issues
ok (for Darwin and friends)
> > src/raster/r.in.gdal/main.c
> > convert ellipsoid name to lower case (bug #1047)
ok
> > src/raster/r.mapcalc3/Gmakefile
> > src/raster/r.mapcalc3/mapcalc.l
> > fix bug with quoted map names
ok
> > src/raster/r.mapcalc3/main.c
> > allow expression to be split into multiple arguments
ok
> > src/raster/r.mapcalc3/xexp.c
> > allow two-argument form
ok
> > src/raster/r.proj/cmd/bordwalk.c
> > ignore invalid points
no idea - is the bordwalk issue clarified now? Morten?
> > src/raster/r.proj/cmd/main.c
> > src/raster/r.proj/cmd/r.proj.h
> > tidy
> > add -n (nocrop) flag
> > move "menu" array from r.proj.h to main.c
> > src/sites/s.in.mif/Gmakefile
> > fix lex invocation
ok
> These are harmless, so may as well be included:
> > mk/Makefile.in
> > generate more complex "gmake5" script
> > mk/mid.mk
> > mk/mid.mk.shlib
> > add LOCALE definition
> > mk/mkmakefiles
> > optional directory argument
all ok
> These are worth considering:
> > configure
> > configure.in
> > readline
> > src/CMD/head/head.in
> > readline variables
> > src/include/config.h.in
> > HAVE_READLINE_READLINE_H
> > readline support
should be quite harmless as it is 1 optional
function only (have tested o.k)
> > src/raster/r.mapcalc3/evaluate.c
> > src/raster/r.mapcalc3/map.c
> > src/raster/r.mapcalc3/mapcalc.h
> > copy cats/colr/hist
please yes.
> > src/libes/gis/reclass.c
> > disable reclassed_to warning
also yes.
Thanks for the investigation, Glynn!
Markus
