[GRASS5] GRASS 5.0.0stable to be released soonish
Glynn Clements glynn.clements at virgin.net
Sat Jun 8 15:47:52 EDT 2002
Glynn Clements wrote:
> > since all release critical bugs are fixed, we should release
> > GRASS 5.0.0stable now.
> > For that we can use the existing pre4 branch. Maybe Glynn could
> > check if any important change was not submitted to (post-)pre4
> > branch?
> OK, I'll look into it. However, 257 files differ between pre4 and the
> head, so it may take a while to check everything.
Fortunately, many of them correspond to bulk changes.
The following is a brief summary of the differences between pre4 and
the current state of the head. Files or changes which are preceded by
an asterisk have already been committed to the release branch.
For the remaining changes, I would appreciate opinions as to which
should be included in the next release. I'll submit my opinions in a
follow-up.
Also, if any fundamental changes are to be included (e.g. the libgis
I18N), we should consider labelling the next release as "pre5" rather
than "final".
Glynn Clements <glynn.clements at virgin.net>
Added directories
locale/ru/tcltkgrass
src/display/d.text.freetype/vflib
Added Files
locale/ru/LC_MESSAGES/libgis.po
	libgis I18N
locale/ru/grass_intro.txt
locale/ru/license.txt
src/general/init/license.txt
	Init.sh I18N
src/libes/proj/PJ_krovak.c
src/libes/proj/PJ_krovakgis.c
	krovak[gis] addition
src/display/d.text.freetype/test.input
	d.text.freetype command mode
Changed Files
AUTHORS
	re-format long lines
NEWS.html
	updated
documents/debugging.txt
	comment re: -W[error-]implicit-function-declaration
	add section 6: Debugging with 'core' file
documents/release_rules.txt
	updated
handheld/babyGRASS_compile.sh
handheld/babyGRASS_packagingsrc.sh
	add g.mapsets
SUBMITTING
	header ordering
Makefile.in
	handling of "locale" subdirectory
configure
configure.in
	readline
	Darwin iconv check
	Darwin PostgreSQL (-lssl -lcrypto)
* documents/cygwin_grass50bininstall.html
	sunrpc library
html/Gmakefile
	[ -> test
	mkdir -> mkdir -p
html/html/d.his.html
	-n flag
* html/html/d.rast.pg.html
* html/html/d.site.pg.html
* html/html/d.what.r.pg.html
* html/html/d.what.s.pg.html
* html/html/d.what.v.pg.html
* html/html/g.column.pg.html
* html/html/g.select.pg.html
* html/html/g.stats.pg.html
* html/html/g.table.pg.html
* html/html/pg.in.dbf.html
	koi8-r -> iso-8859-1
html/html/d.vect.pg.html
*	koi8-r -> iso-8859-1
	-e flag
* html/html/v.reclass.pg.html
	fix postgresql.org URL
* html/html/v.to.pg.html
	-p flag
	change xrefs
html/html/d.text.freetype.html
	-rpsc flags
	align=, rotation=
	Command mode
html/html/dcorrelate.sh.html
	mention "scattergram"
html/html/i.rectify.html
	comment regarding write errors
html/html/i.in.erdas.html
	r.in.gdal xref
	authors
* html/html/m.datum.shift.html
html/html/s.in.garmin.sh.html
	change xrefs
html/html/pngdriver.html
	default background is black
html/html/r.his.html
	-n flag
* html/html/r.runoff.html
	G-language -> GRASS raster command
html/html/s.in.ascii.html
	Time as String Attributes
* html/html/s.vol.rst.html
	references
html/html/s.what.html
	Add mailto: link
html/html/v.in.garmin.sh.html
*	gps -> GPS
	change xrefs
html/html/v.in.shape.html
	-d flag
html/index.html
*	update search URL
	update mailto: link
html/projections.html
	add URLs
html/raster.html
	remove xrefs
* html/searchhtml.html
	update search URL
html/tips_and_tricks.html
	Add comment re: .cshrc
locale/Gmakefile
	process all locales, not $LANG
	add tcltkgrass, textintro targets
locale/ru/LC_MESSAGES/d.vect.pg.po
locale/ru/LC_MESSAGES/v.to.pg.po
mk/Makefile.in
	add "locale" subdirectory to "dirs" target
	generate more complex "gmake5" script
mk/mid.mk
mk/mid.mk.shlib
	add LOCALE definition
mk/mkmakefiles
	optional directory argument
src.contrib/GMSL/SG3d/README
src.contrib/GMSL/sg4d/README
	mention Ygl
src.garden/grass.hdf/hdf5/r.in.hdf/README
	mention HDF-EOS
src.garden/grass.hdf/hdf5/r.in.hdf/r.in.hdf.c
src.garden/grass.postgresql/d.vect.pg/dbvect.h
src.garden/grass.postgresql/d.vect.pg/getAllOpts.c
src.garden/grass.postgresql/d.vect.pg/getSopts.c
src.garden/grass.postgresql/d.vect.pg/main.c
src.garden/grass.postgresql/d.vect.pg/runInfxFile.c
	-e (extract) flag
src.garden/grass.postgresql/v.to.pg/dbvect.h
src.garden/grass.postgresql/v.to.pg/getAllOpts.c
src.garden/grass.postgresql/v.to.pg/getSopts.c
src.garden/grass.postgresql/v.to.pg/main.c
src.garden/grass.postgresql/v.to.pg/plotCat.c
src.garden/grass.postgresql/v.to.pg/runInfxFile.c
	-p (postgis) flag
* src/CMD/generic/GISGEN.sh
src/CMD/generic/make.mid
	define LOCALE (currently unused)
src/CMD/head/head.in
	readline variables
src/display/d.3d/Dmain.c
src/display/d.3d/check_opt.c
src/display/d.3d/command.c
src/display/d.area/main.c
src/display/d.area/screenpoly.c
src/display/d.barscale/cmd/main.c
src/display/d.barscale/cmd/mouse.c
src/display/d.colormode/cmd/main.c
src/display/d.colors/get_info.c
src/display/d.colortable/cmd/main.c
src/display/d.db/main.c
src/display/d.extend/cmd/main.c
src/display/d.font/cmd/main.c
src/display/d.frame/cmd/create.c
src/display/d.frame/cmd/dumper.c
src/display/d.frame/cmd/select.c
src/display/d.geodesic/cmd/main.c
src/display/d.graph/cmd/allocation.c
src/display/d.graph/cmd/main.c
src/display/d.grid/cmd/main.c
src/display/d.histogram/cmd/get_stats.c
src/display/d.icons/cmd/main.c
src/display/d.label/cmd/main.c
src/display/d.leg.thin/main.c
src/display/d.mapgraph/cmd/main.c
src/display/d.menu/cmd/main.c
src/display/d.mon/pgms/release.c
src/display/d.mon/pgms/start.c
src/display/d.mon/pgms/stop.c
src/display/d.mouse/main.c
src/display/d.pan/main.c
src/display/d.points/cmd/main.c
src/display/d.profile/What.c
src/display/d.profile/main.c
src/display/d.rast/cmd/display.c
src/display/d.rast/cmd/main.c
src/display/d.rhumbline/cmd/main.c
src/display/d.sites.qual/cmd/main.c
src/display/d.sites/cmd/main.c
src/display/d.title/cmd/main.c
src/display/d.vect.labels/main.c
src/display/d.vect/cmd/main.c
src/display/d.what.db/main.c
src/display/d.what.vect/cmd/attr.c
src/display/d.what.vect/cmd/main.c
src/display/d.where/cmd/main.c
src/display/d.zoom/cmd/main.c
src/general/g.gisenv/main.c
src/general/g.help/main.c
src/general/g.help/menu.c
src/general/g.manual/cmd/main.c
src/general/g.manual/inter/main.c
src/general/g.mapsets/dsply_path.c
src/general/g.mapsets/main_cmd.c
src/general/g.parser/main.c
src/general/g.region/cmd/main.c
src/general/g.region/cmd/printwindow.c
src/general/g.region/cmd/zoom.c
src/general/g.region/inter/main.c
src/general/g.setproj/main.c
src/general/init/lock.c
src/general/manage/cmd/copy.c
src/general/manage/cmd/rename.c
src/general/manage/lib/read_list.c
src/libes/dbmi/lib/dbmscap.c
* src/raster/r.sun/main.c
	various tidying:
		include necessary headers
		remove unused variables
		error handling changes
		use $GRASS_PAGER instead of $PAGER
		remove $Log$
src/display/d.his/cmd/main.c
src/raster/r.his/cmd/main.c
	-n flag
src/display/d.text.freetype/Gmakefile
src/display/d.text.freetype/freetypecap
src/display/d.text.freetype/main.c
	add align=, rotation= options
	command mode
src/display/devices/PNGdriver/Graph_Set.c
	Fix GRASS_BACKGROUNDCOLOR processing
src/display/devices/PNGdriver/README
src/display/devices/XDRIVER/XDRIVER24/Graph_Set.c
	add "GRASS" to monitor title (tcltkgrass bug workaround)
src/general/init/Gmakefile
	generate $GISBASE/etc/license
	link $GISBASE/etc/lock against libgis
src/general/init/init.sh
*	add "savehist" setting to .cshrc
	i18n
	licence notice moved to separate file
* src/imagery/i.points/ask_mag.c
* src/imagery/i.points3/inter/graph_askmag.c
* src/imagery/i.vpoints/ask_mag.c
	add R_flush()
* src/imagery/i.vpoints/cell.c
* src/imagery/i.vpoints/colors.c
src/imagery/i.vpoints/debug.c
* src/imagery/i.vpoints/drawcell.c
* src/imagery/i.vpoints/drawvect.c
* src/imagery/i.vpoints/driver.c
src/imagery/i.vpoints/globals.h
src/imagery/i.vpoints/main.c
src/imagery/i.vpoints/zoom_box.c
	various changes
src/include/config.h.in
	HAVE_READLINE_READLINE_H
src/include/geo.h
src/libes/gis/geo_init.c
src/libes/gis/projections
src/libes/proj/Gmakefile
src/libes/proj/pj_list.h
	krovak[gis] added
src/libes/edit/edit_cellhd.c
	fix rounding of negative values
src/libes/gis/datum.table
src/libes/proj/pj_datums.c
	Hermannskogel added
src/libes/gis/env.c
	check for empty string in set_env()
	I18N
src/libes/gis/reclass.c
	disable reclassed_to warning
	I18N
src/libes/gis/Gmakefile
src/libes/gis/G_dump.c
src/libes/gis/adj_cellhd.c
src/libes/gis/ask.c
src/libes/gis/ask_cell.c
src/libes/gis/auto_mask.c
src/libes/gis/cats.c
src/libes/gis/closecell.c
src/libes/gis/color_read.c
src/libes/gis/datum.c
src/libes/gis/done_msg.c
src/libes/gis/error.c
src/libes/gis/format.c
src/libes/gis/get_cellhd.c
src/libes/gis/get_datum.c
src/libes/gis/get_datum_name.c
src/libes/gis/get_ell_name.c
src/libes/gis/get_ellipse.c
src/libes/gis/get_projinfo.c
src/libes/gis/get_projname.c
src/libes/gis/get_row.c
src/libes/gis/get_window.c
src/libes/gis/gishelp.c
src/libes/gis/gisinit.c
src/libes/gis/histogram.c
src/libes/gis/history.c
src/libes/gis/home.c
src/libes/gis/legal_name.c
src/libes/gis/list.c
src/libes/gis/location.c
src/libes/gis/make_colr.c
src/libes/gis/mapset.c
src/libes/gis/mapset_msc.c
src/libes/gis/mask_info.c
src/libes/gis/myname.c
src/libes/gis/null_val.c
src/libes/gis/opencell.c
src/libes/gis/parser.c
src/libes/gis/proj2.c
src/libes/gis/proj3.c
src/libes/gis/put_cellhd.c
src/libes/gis/put_row.c
src/libes/gis/put_title.c
src/libes/gis/quant_io.c
src/libes/gis/quant_rw.c
src/libes/gis/range.c
src/libes/gis/rd_cellhd.c
src/libes/gis/readsites.c
src/libes/gis/readsites_xyz.c
src/libes/gis/set_window.c
src/libes/gis/system.c
src/libes/gis/timestamp.c
src/libes/gis/view.c
	I18N
* src/libes/proj/datum_shift.c
	check for no datum specified
src/libes/proj/geod.c
	re-order headers to deal with geodesic.h issues
* src/mapdev/v.in.shape/main.c
	-d flag
	error handling
* src/mapdev/v.mkgrid/mkgrid_cmd.c
	fix key_desc field of "box=" option
src/mapdev/v.proj/Gmakefile
* src/mapdev/v.proj/main.c
* src/sites/s.proj/main.c
	datum/ellipse fixes
src/raster/r.in.gdal/main.c
	convert ellipsoid name to lower case (bug #1047)
src/raster/r.mapcalc3/Gmakefile
src/raster/r.mapcalc3/mapcalc.l
	readline support
	fix bug with quoted map names
src/raster/r.mapcalc3/evaluate.c
src/raster/r.mapcalc3/map.c
src/raster/r.mapcalc3/mapcalc.h
	copy cats/colr/hist
src/raster/r.mapcalc3/main.c
	allow expression to be split into multiple arguments
src/raster/r.mapcalc3/xexp.c
	allow two-argument form
src/raster/r.proj/cmd/bordwalk.c
	ignore invalid points
src/raster/r.proj/cmd/main.c
src/raster/r.proj/cmd/r.proj.h
*	datum/ellipse fixes
	tidy
	add -n (nocrop) flag
	move "menu" array from r.proj.h to main.c
* src/raster/r.tiff/r.out.tiff.c
	fix allocation bug
* src/scripts/contrib/d.rast.rescale/d.rast.rescale
	add "help" option
	fix r.stats invocation (-z -> -n)
src/scripts/contrib/grassmirrorsmap/grass.sites.mirror
	add Canada, Venezuela
src/scripts/contrib/grassmirrorsmap/grass_sites.gif
src/scripts/contrib/grassmirrorsmap/grass_sites.htmlmap
src/scripts/contrib/grassmirrorsmap/grassmap.html
	updated
src/scripts/contrib/grassmirrorsmap/list_countries.sh
	add g.gisenv call
src/scripts/contrib/grassmirrorsmap/mkgrassmap.sh
	add more colors
src/scripts/contrib/r.univar/r.univar
	/bin/bash -> /bin/sh
	change Markus' email address
src/sites/s.in.mif/Gmakefile
	fix lex invocation
src/tcltkgrass/main/gis_set.tcl
src/tcltkgrass/tcltkgrass
	I18N
* src/tcltkgrass/module/d.his
	-n switch
src/tcltkgrass/module/d.zoom
	more options
Bogus Diffs
src/libes/gis/sites.c
src.contrib/GMSL/NVIZ2.2/src/togl.c
