[GRASS5] GRASS 5.0.0stable to be released soonish
Bernhard Reiter
bernhard at intevation.de
Tue Jun 11 09:31:06 EDT 2002
On Sat, Jun 08, 2002 at 08:47:52PM +0100, Glynn Clements wrote:
> > > since all release critical bugs are fixed, we should release
> > > GRASS 5.0.0stable now.
> > > For that we can use the existing pre4 branch. Maybe Glynn could
> > > check if any important change was not submitted to (post-)pre4
> > > branch?
> > OK, I'll look into it. However, 257 files differ between pre4 and the
> > head, so it may take a while to check everything.
> Fortunately, many of them correspond to bulk changes.
We will not include them.
I strongly advise against merging now.
We should run checks for the release branch code and then release it
as 5.0.0 or pre5.
> Also, if any fundamental changes are to be included (e.g. the libgis
> I18N), we should consider labelling the next release as "pre5" rather
> than "final".
No fundamental changes. Only critical bug fixes.
And everybody should have committed them already to the release branch.
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20020611/964e2d6a/attachment.bin
