[GRASS5] [building questions]
Markus Neteler neteler at itc.it
Mon Jun 17 02:08:20 EDT 2002
Hi Sergiusz
On Sun, Jun 16, 2002 at 07:33:10PM +0200, --s+ wrote:
> 2. Build GRASS:
you mean the release-docs,right?
> o compile everything, incl NVIZ without PG (note, no ";" to
>   be used):
> 	      CFLAGS=-O2 LDFLAGS="-s" ./configure --without-postgres
> 	      make
Because often people do not have the PG libs installed. We had
that problem with a release in the past, that's why we decided
to go for the "minimum" impact compilation to enable
everybody to use NVIZ.
Note that for *.pg compilation PG must be enabled again (see release-doc).
Markus
