[GRASS5] [building questions]
Sergiusz Pawlowicz ser at it-zone.org
Mon Jun 17 06:18:43 EDT 2002
--->[Quoting Markus Neteler <neteler at itc.it>:]
> you mean the release-docs,right?
yeah - release_rules.txt
> > o compile everything, incl NVIZ without PG (note, no ";" to
> >   be used):
> >           CFLAGS=-O2 LDFLAGS="-s" ./configure --without-postgres
> >           make
> Because often people do not have the PG libs installed. We had
> that problem with a release in the past, that's why we decided
> to go for the "minimum" impact compilation to enable
> everybody to use NVIZ.
Ok - so what do you think about releasing several sets
of grass binaries - with different libraries compiled in?
Sergiusz
      http://ibiblio.org/ser/ | http://it-zone.org/
_________________________________________________________
tldp.org|gnu.org|hyperreal.info|pld-linux.org|it-zone.org
  "The moon is made of green cheese." -- John Heywood
