[GRASS5] Re: [GRASS-CVS] glynn: grass/src/...
Glynn Clements glynn.clements at virgin.net
Mon Jun 17 11:57:58 EDT 2002
Markus Neteler wrote:
> thanks for updating the release branch.
> What I do not fully understand:
> On Sun, Jun 16, 2002 at 05:29:52PM +0200, grass at intevation.de wrote:
> > Author: glynn
> > Update of /grassrepository/grass/src/CMD/generic
> > In directory doto:/tmp/cvs-serv19045/src/CMD/generic
> > Modified Files:
> >       Tag: releasebranch_26_april_2002_5_0_0
> [ files]
> > Sync with CVS head
> why 'releasebranch_26_april_2002_5_0_0'? We had a more recent
> branch already:
> GRASS 5.0.0pre4: has been tagged as "release_13_may_2002_grass5_0_0_pre4"
This isn't a branch tag. This is a normal (non-branch) tag which was
applied to those files which constituted the pre4 release.
If you use:
	cvs update -r releasebranch_26_april_2002_5_0_0
you will get the latest versions from the release branch; more or less
the files that will constitute pre5.
If you use:
	cvs update -r release_13_may_2002_grass5_0_0_pre4
you should get the files which constitute pre4.
Glynn Clements <glynn.clements at virgin.net>
