[GRASS5] Re: [GRASS-CVS] glynn: grass/src/...
Markus Neteler
neteler at itc.it
Mon Jun 17 12:05:09 EDT 2002
On Mon, Jun 17, 2002 at 04:57:58PM +0100, Glynn Clements wrote:
> Markus Neteler wrote:
> > thanks for updating the release branch.
> > What I do not fully understand:
> > On Sun, Jun 16, 2002 at 05:29:52PM +0200, grass at intevation.de wrote:
> > > Author: glynn
> > > Update of /grassrepository/grass/src/CMD/generic
> > > In directory doto:/tmp/cvs-serv19045/src/CMD/generic
> > > Modified Files:
> > > Tag: releasebranch_26_april_2002_5_0_0
> > [ files]
> > > Sync with CVS head
> > why 'releasebranch_26_april_2002_5_0_0'? We had a more recent
> > branch already:
> > GRASS 5.0.0pre4: has been tagged as "release_13_may_2002_grass5_0_0_pre4"
> This isn't a branch tag. This is a normal (non-branch) tag which was
> applied to those files which constituted the pre4 release.
> If you use:
> cvs update -r releasebranch_26_april_2002_5_0_0
> you will get the latest versions from the release branch; more or less
> the files that will constitute pre5.
> If you use:
> cvs update -r release_13_may_2002_grass5_0_0_pre4
> you should get the files which constitute pre4.
Ah yes, now I recall that (sorry). Maybe we should improve the
web page to be more clear. Suggestions welcome (or directly
modify the file in web CVS).
Markus
