[GRASS5] Re: [GRASS-CVS] glynn: grass/src/...
Carl Worth
cworth at east.isi.edu
Mon Jun 17 14:35:14 EDT 2002
On Jun 17, Glynn Clements wrote:
> If you use:
> cvs update -r release_13_may_2002_grass5_0_0_pre4
> you should get the files which constitute pre4.
Why do these tags have two independent naming schemes embedded within
them:
1) a date
2) a release number
I can imagine reasons it might be nice to have tags that include dates
in them, (for example to be able to reproduce a hypothetical nightly
"snapshot" tarball). Otherwise, a tag with a date doesn't seem to
helpful since CVS can provide code for a specific date anyway.
Getting to the point, currently it's hard to deduce the tag for a
given release, (one must consult a list giving the dated tag name
above).
I would prefer a system that had simpler tag names that a mere mortal
could actually predict such as:
cvs update -r release_5_0_0_pre4
-Carl
Carl Worth
USC Information Sciences Institute cworth at east.isi.edu
3811 N. Fairfax Dr. #200, Arlington VA 22203 703-812-3725
