[GRASS5] Re: [GRASSLIST:3916] Re: Grass5.0.0pre4 Installation Problems(cont.)
Glynn Clements glynn.clements at virgin.net
Thu Jun 20 10:21:26 EDT 2002
[CC'd to GRASS developers' list.]
Neil.Murphy at axa.ie wrote:
> Here is the result from  gmake5 src/libes/edit".
>  In function `format_value':
> edit_cellhd.c:112: Internal compiler error in subst_stack_regs_pat, at
> reg-stack.c:
> 1414Please submit a full bug report.
> See <URL:https://qa.mandrakesoft.com/> for instructions.
This exact same message has been reported before, in:
	Subject: [GRASSLIST:3697] Re: Compile Grass5.0.0pre4
	Date: Tue, 21 May 2002 14:52:58 +0200
	Message-Id: <GWGP4A$59DCDBBBEE9974BC403CD984877FA5A9 at respublica.fr>
He reported that "gcc -v" said:
	Reading specs from /usr/lib/gcc-lib/i586-mandrake-linux-gnu/2.96/specs
	gcc version 2.96 20000731 (Mandrake Linux 8.2 2.96-0.76mdk)
Presumably this is the one from the Mandrake 8.2 CD?
You may need to replace your copy of gcc with an updated version.
However, another poster reported success on Mandrake 8.2 with:
	CFLAGS="-O3 -mcpu=pentiumpro -Wall" LDFLAGS="-s" ./configure ...
Glynn Clements <glynn.clements at virgin.net>
