[GRASS5] v.in.mif currently broken ?
Bernhard Reiter
bernhard at intevation.de
Fri Jun 21 08:47:05 EDT 2002
I commented out the corresponding line for v.in.mif in lists/GRASS
because of the information below.
On Fri, Jun 21, 2002 at 01:30:47AM +0200, Moritz Lennert wrote:
> Just for info: it's still enabled in the
>(current for the next few days ;-) pre4 releasei,
> at least when built from source.
> On Thu, Jun 20, 2002 at 09:47:24PM +0100, David D Gray wrote:
> > The current code is not usable at all. It is disabled from the default
> > build so will not appear in binary releases. A module based on existing
> > modules like v.in.shape is in development, but key parts still have to
> > be coded, tested etc, so it is not ready for the stable release, which
> > is now effectively frozen.
> > > Am I correct in understanding that v.in.mif is currently broken ?
> > > If yes, what are the alternatives ?
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20020621/1a0ac27a/attachment.bin
