[GRASS5] [bug #920] (grass) d.vect.line does not draw lines
M Lennert fa1079 at qmul.ac.uk
Mon Mar 4 07:14:45 EST 2002
On 24 Feb 02, at 20:36, Eric G. Miller wrote:
> I believe I've corrected the slow line drawing.  Also "none" will now
> disable fill or line drawing (or both!).
I finally got around to trying this. Yes, the line drawing is now the same speed as with d.vect.
Thanks a lot !
Moritz
