[GRASS5] French projections
Markus Neteler
neteler at itc.it
Thu Mar 7 09:02:20 EST 2002
On Thu, Mar 07, 2002 at 09:42:18AM +0000, Michel Wurtz wrote:
> Speaking about updating projection definitions, I have noticed that
> lcc (Lambert Conformal conic) doesn't have false easting or northing
> (at least when using g.setproj).
That is surprising: in geo_init.c is defined:
TABLE[LCC][LAT0].ask = 1;
TABLE[LCC][LAT0].def_exists = 1;
TABLE[LCC][LAT0].deflt = 23.0;
TABLE[LCC][LON0].ask = 1;
TABLE[LCC][LON0].def_exists = 1;
TABLE[LCC][LON0].deflt = -96.0;
TABLE[LCC][LAT1].ask = 1;
TABLE[LCC][LAT1].def_exists = 1;
TABLE[LCC][LAT1].deflt = 33.0;
TABLE[LCC][LAT2].ask = 1;
TABLE[LCC][LAT2].def_exists = 1;
TABLE[LCC][LAT2].deflt = 45.0;
TABLE[LCC][X0].ask = 1;
TABLE[LCC][X0].def_exists = 1;
TABLE[LCC][X0].deflt = 0.0;
TABLE[LCC][Y0].ask = 1;
TABLE[LCC][Y0].def_exists = 1;
TABLE[LCC][Y0].deflt = 0.0;
So it should ask for x_0 and y_0. Obviously there is another
test somewhere to suppress that?
> On the other hand, France will now
> use a new system (Lambert 93) based on GRS80 ellispoid, instead of
> the old one (a familly of lcc projections) based on Clarke 1880
> ellipsoid (IGN modified). This has lead to a conversion grid for
> precise transformation (something like NAD27/NAD83).
> Since proj has the ability to use such a grid, it sounds relatively
> easy to incorporate french geodetic systems. All the détails
> parameters, formulas and algorithms can be found (in french :-) at
> http://www.ign.fr/fr/PI/activites/geodesie/rgf93/OUTILS/index.html
This sounds like a datum transform...
Markus
