[GRASS5] Shapelib
Fri Mar 22 10:33:23 EST 2002
David says:
>>As to the properties of shapefiles, it is confusing. The spec allows
>>each `shape' to have its own type defined independently, but AFAIK this
>>is not  yet (and probably now won't be) supported in ArcView, so
>>presumably most implementors avoid this. That is why the export for
>>GRASS was written to create layers in separate files.
David / Markus,
While each shape include a shape type with it, it has never been allowed
to created a mixture of types with the exception that null-geometry shapes
may be mixed in a file in some cases.
Markus says:
> Hi David,
> just curious: Are the SHAPE engine of GRASS (shape lib) and the SHAPELIB
> in GDAL/OGR still in sync. At least they are not in CVS.
> It might be a good idea to synchronize again as Frank Warmerdam and others
> put some efforts into the SHAPELIB (frmts/shapelib in GDAL/OGR).
> In general we may need a better solution how to deal with such important
> libraries from 3rd parties. Hosting them as well in GRASS CVS will
> tend to consolidate the non-synchronisation.
There have been no significant changes to shapelib for the purposes of GRASS.
I will try to remember to update the GRASS shapelib if there ever is a
significant change.  However, for something small like Shapelib I think
maintaining a copy within GRASS CVS is appropriate.
Best regards,
