[GRASS5] Zoom
Glynn Clements
glynn.clements at virgin.net
Fri May 3 05:03:57 EDT 2002
Radim Blazek wrote:
> > Hmm. I see some utility in being able to flag whether the datasource
> > will be used for input, output, or input and output. Pretty much every
> > module has to go through a bunch of checks for this, so why not have the
> > parser handle it? The behavior might change if we move away from only
> > being able to edit/write data in the current mapset.
> I think, that most of modules, should not open vectors for update
> (input and output, if I understand you well). Then data may not be lost,
> if module crashes or incorect parameter is specified. The only
> module which should update old vector is v.digit.
> I agree, that some checks should be done by parser, but some probably
> by *_open(). Typically:
> 1) map existence should be checked by parser and error printed, if necessary
> 2) error should be reported by *_open(), if it fails to open the map
More generally, most library functions should just call
G_fatal_error() whenever an exceptional condition occurs, rather than
returning NULL/0/1/-1/non-zero or whatever.
It is possible to define a fatal error handler, so programs which need
to continue in the presence of errors can do so.
> I don't know, on which level should be checked, if the new map already exist,
> (that needs some system, how to tell to parser/open function, if should
> a)work interactively (ask what to do), b) overwrite or c) quit.
I have wondered if it would be worth having the parser handle certain
flags and options automatically. In this case, having it recognise
"-o" as an indication to overwrite existing output maps.
Other special flags might include -v and/or -q for verbose/quiet
operation; this would automatically affect G_percent(), plus a
hypothetical G_message() function, and maybe G_warning().
Special options might include "dbase=", "location=" and "mapset=".
> > > V_CATS may be something like '1,3,7-9,11' and may be parsed by
> > > Vect_str_to_cat_list (char *str, struct cat_list *list);
OK; I wouldn't expect applying a generic "list" constructor to the
primitive "category" type to handle that. But you could have a
primitive "category range" type, and have "list of category range" as
a derived type.
Glynn Clements <glynn.clements at virgin.net>
