[GRASS5] ANN: GRASS on iPAQ/Linux available
Markus Neteler
neteler at itc.it
Tue May 7 11:48:59 EDT 2002
On Tue, May 07, 2002 at 03:39:13PM +0000, Carl Worth wrote:
> On May 7, Markus Neteler wrote:
> > Jan Stankovic and me may announce that (baby)GRASS is
> > running now on iPAQ/Linux:
> > http://grass.itc.it/grasshandheld.html
> I'll follow that up by announcing that I've packaged up these same
> binaries and contributed them to the Familiar distribution.
> This means, that iPAQ users running Familiar can now simply do:
> ipkg install grass
> to download and install grass. This will currently work as long as the
> user is pointing at Familiar's "unstable" feed[*]. By the time
> Familiar 0.5.3 is released, grass will be available as part of the
> standard distribution.
> If someone would like to install the package without pointing at the
> unstable feed, then the following command will also work:
> ipkg install http://familiar.handhelds.org/familiar/feeds/unstable/packages/armv4l/grass_5.0.0-20020507-1_arm.ipk
Congrats, Carl!
> A few notes on the package I made:
> o It installs its binary as /usr/bin/grass5
> o All other files are in /usr/share/grass/,
> (eg. /usr/share/grass/bin, /usr/share/grass/etc, etc.) This
> layout matches standard (FHS) practice and is cleaner than
> installing directories such as
> dist.armv4l-unknown-linux-gnu. Perhaps I should change it to
> /usr/share/grass5 though?
> o There is a bug in ipkg preventing it from installing
> packages with hard links correctly. So I expanded all the
> files in /usr/share/grass/bin into separate files. This bloats
> the package a bit, but I also stripped all the libraries which
> compensates almost exactly. (I plan to fix the bug in ipkg
> soon *blush*).
> Things I would like to do next include making all of GRASS available
> in separate packages, creating a better mechanism for doing partial
> builds of grass, and adding package creation targets to the GRASS
> makefiles.
Yes - my scripts are pretty rough. We need a more conventient method.
Carl, may I ask you to add your notes to
web/grasshandheld.html
cvs -z3 co web
will get the pages to you.
> > Notes:
> > - we have to look again at d.zoom to get the 1-button mode working
> > (it runs on iX86/Linux, but not on iPAQ)
> I'll be looking into this right away.
Perfect.
> > - we still do not get "debugging symbols" present, but anyway - GRASS
> > is working now
> Markus, you asked for this. Your script passes "-s" to ld which
> removes the debugging symbols, (although strip can shrink the
> libraries you generated a bit more).
I am not sure - I had disabled LDFLAGS="". In the head file is written
src/CMD/head/head
CC = gcc
FC =
LEX = flex
COMPILE_FLAGS = -g -gstabs
LINK_FLAGS =
There is no "-s", also not in the script (see latest CVS version):
CFLAGS="-g -gstabs" LDFLAGS="" ./configure --prefix=...
Still there are no debugging symbols.
cd dist.armv4l-unknown-linux-gnu/etc/bin/cmd
gdb d.vect
GNU gdb 2002-04-01-cvs
This GDB was configured as "arm-linux"...(no debugging symbols found)...
(gdb)
There must be another trick.
Markus
