[GRASS5] ANN: GRASS on iPAQ/Linux available
Glynn Clements
glynn.clements at virgin.net
Tue May 7 20:33:14 EDT 2002
Carl Worth wrote:
> o All other files are in /usr/share/grass/,
> (eg. /usr/share/grass/bin, /usr/share/grass/etc, etc.) This
> layout matches standard (FHS) practice and is cleaner than
> installing directories such as
> dist.armv4l-unknown-linux-gnu. Perhaps I should change it to
> /usr/share/grass5 though?
/usr/share is supposed to be for files which are shareable across
architectures, i.e. not executables or libraries. I suggest using
/opt.
Basically, the GISBASE concept (i.e. all of GRASS residing within a
single directory) is at odds with the conventional Unix directory
structure (files grouped by type rather than by package) of FHS.
> o There is a bug in ipkg preventing it from installing
> packages with hard links correctly. So I expanded all the
> files in /usr/share/grass/bin into separate files. This bloats
> the package a bit, but I also stripped all the libraries which
> compensates almost exactly. (I plan to fix the bug in ipkg
> soon *blush*).
Rather than making lots of copies of front.end, either use symlinks,
or generate the links with an installation script.
Glynn Clements <glynn.clements at virgin.net>
