[GRASS5] Imagery GROUP file
Markus Neteler
neteler at itc.it
Thu May 9 04:37:20 EDT 2002
A reminder:
Below GROUP/SUBGROUP changes still need to be described:
- in the NEWS.html file [I can do that]
- in the Programmer's manual [I can do that]
- for the imagery_dataset [I can do that]
Somewhere else?
Markus
On Sat, Apr 13, 2002 at 06:14:36AM +0100, Glynn Clements wrote:
> The use of the name "GROUP" for file which stores the current imagery
> group conflicts with the "group" directory on filesystems which
> perform case folding.
> Someone has added a fix specifically for Cygwin:
> #ifdef __CYGWIN__
> #define GROUPFILE "CURGROUP"
> #else
> #define GROUPFILE "GROUP"
> #endif
> #ifdef __CYGWIN__
> #define SUBGROUPFILE "CURSUBGROUP"
> #else
> #define SUBGROUPFILE "SUBGROUP"
> #endif
> However:
> 1. The same problem may occur with MacOS X, where case-folding
> filesystems are not uncommon.
> 2. Users of conventional Unices might access a GRASS database which is
> stored on a case-folding filesystem, e.g. an SMB share which is used
> by both Unix and Windows systems, or a FAT partition on a dual-boot
> Linux/Windows box.
> 3. This creates a portability problem regarding distributed datasets
> (e.g. the "imagery" dataset, which includes a GROUP file).
> Consequently, I've changed the definitions so that the files are
> always called CURGROUP and CURSUBGROUP.
> Users will need to rename (or re-create) any GROUP/SUBGROUP files
> after updating to the new code.
> Also, any supplied datasets (e.g. "imagery") will need to be updated.
> Glynn Clements <glynn.clements at virgin.net>
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
