[GRASS5] Re: [GRASS-CVS] bernhard: grass SUBMITTING,1.21,1.22
Glynn Clements
glynn.clements at virgin.net
Mon May 13 15:44:38 EDT 2002
Bernhard Reiter wrote:
> As you can see a slightly adapted version of syncmail
> (http://sourceforge.net/projects/cvs-syncmail/)
> is running on the GRASS cvs server now.
> It only generates emails for the modules web and grass right now.
> Do you want commit messages for all modules?
> On the topic above: I still believe that we should put ID
> tags in files. The statement that this makes problems with
> branches does not seem to be completly correct.
It's not that big a deal. If I were doing another big merge, I'd just
check out everything with -kk. Keyword substitution is only really
important for generating source tarballs.
The worst case is $Log$, as the effects aren't restricted to the line
containing the keyword. In all other cases, you can use "diff -I ..."
to ignore differences caused by keyword substitution.
Glynn Clements <glynn.clements at virgin.net>
