[GRASS5] g.region G_usage() commented out?
Glynn Clements
glynn.clements at virgin.net
Wed May 15 05:45:17 EDT 2002
Eric G. Miller wrote:
> > What about changing die() so that it also prints the ->description
> > string? Like the diff below? It's not perfect, but it's an
> > improvement.
> > diff -u -r1.8 main.c
> > --- src/general/g.region/cmd/main.c 22 Jan 2002 04:51:04 -0000 1.8
> > +++ src/general/g.region/cmd/main.c 15 May 2002 04:34:35 -0000
> > @@ -704,7 +704,7 @@
> > static void die(struct Option *parm)
> > - fprintf(stderr,"<%s=%s> ** illegal value **\n\n", parm->key, parm->answer);
> > + fprintf(stderr,"<%s=%s> not recognized, expecting:\n%s\n", parm->key, parm->answer, parm->description);
> > G_usage();
> I'm not sure that adds anything to the error report.
Well, the description field will indicate that the format has to be
dd:mm:ss for lat/lon locations.
However, the mechanism which is used involves calling library
functions before G_parser() has returned, which would stop working if
we were implement "standard" options such as "location=".
> On a general note, would it be desirable to have G_{lat|lon|llres}_scan
> fall back to reading doubles and then range check the value?
I would say so.
> Nitpick: I dislike "illegal value". IMHO, "invalid input" is more
> "correct" since the law has nothing to do with the matter. Also, no
> good reason not to use G_fatal_error() here. Technically, exit(1) is
> not well defined either (exit(EXIT_FAILURE) is).
At least exit(1) is an improvement over exit(-1); the latter is all
too common. Also, while exit(1) may not be defined by ANSI C, the
various Unix specifications all dictate that zero indicates success
and non-zero indicates failure.
Glynn Clements <glynn.clements at virgin.net>
