[GRASS5] g.region G_usage() commented out?
Russell Nelson
nelson at crynwr.com
Wed May 15 10:41:39 EDT 2002
Glynn Clements writes:
> > I'm not sure that adds anything to the error report.
> Well, the description field will indicate that the format has to be
> dd:mm:ss for lat/lon locations.
I can't imagine it hurts to give a user more information.
> However, the mechanism which is used involves calling library
> functions before G_parser() has returned, which would stop working if
> we were implement "standard" options such as "location=".
So, you're saying that the entire die() function is not wisely implemented?
> > On a general note, would it be desirable to have G_{lat|lon|llres}_scan
> > fall back to reading doubles and then range check the value?
> I would say so.
Speaking of which, what's this MARKER stuff in those functions? Is
that a holder from the FORTRAN implementation? Anybody mind if I add
code to read doubles and delete the MARKER stuff at the same time?
-russ nelson http://russnelson.com | Okay, enough is enough!
Crynwr sells support for free software | PGPok | Can we PLEASE all stop
521 Pleasant Valley Rd. | +1 315 268 1925 voice | using insecure Microsoft
Potsdam, NY 13676-3213 | +1 315 268 9201 FAX | email products???
