[GRASS5] i18n for tcltkgrass
ser at it-zone.org
ser at it-zone.org
Fri May 17 10:59:37 EDT 2002
--->[Quoting Glynn Clements <glynn.clements at virgin.net>:]
> Alex Shevlakov wrote:
> > I'd like to attempt making permanent changes to tcltk
> > scripts (especially, tcltkgrass) code in order to
> > internationalize them. As much as I know, there
> > is a Tcl built-in 'msgcat' command allowing to
> > internationalize messages.
> AFAICT, the msgcat package was added in Tcl 8.1;
> versions prior to that won't have it.
> Personally, I don't think that it's reasonable to
> require 8.1+ in order to use tcltkgrass. Instead, any
> changes should be made in such a way that tcltkgrass
> continues to work with older versions of Tcl (albeit
> without I18N).
Hello Glynn,
maybe for you internationalisation is not important, but
for me - essencial. We have to do it with minimal
difficulties, of course, but if we have to use newer
Tcl/Tk - we should do it.
http://ibiblio.org/ser/ | http://it-zone.org/
_________________________________________________________
tldp.org|gnu.org|hyperreal.info|pld-linux.org|it-zone.org
"The moon is made of green cheese." -- John Heywood
