[GRASS5] Re: [GRASSLIST:3695] Grass5.0.0pre4's 'make install' dies looking for dist.X/locale
Bernhard Reiter bernhard at intevation.de
Tue May 21 13:05:44 EDT 2002
On Tue, May 21, 2002 at 06:50:46PM +0200, Markus Neteler wrote:
> On Tue, May 21, 2002 at 05:33:27PM +0100, Glynn Clements wrote:
> > > Grass5.0.0pre4 is out apparently.
> > > Trouble is, there is no ./dist.X/locale directory.
> > We need to release an update. This bug is probably going to bite
> > *most* users, as NLS is disabled by default.
> Let's go for the update. I can do that (welcome pre5).
> Glynn, could you check if we can use the pre4 branch? It should
> be still in a good condition.
We must to use the release branch, that's what it is for.
Do you really think we should release pre5 that soon?
We probably find even more release critical bugs...
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20020521/aa48894b/attachment.bin
