[GRASS5] Re: [GRASSLIST:3695] Grass5.0.0pre4's 'make install' dies looking for dist.X/locale
Glynn Clements glynn.clements at virgin.net
Tue May 21 13:23:15 EDT 2002
Bernhard Reiter wrote:
> > > > Grass5.0.0pre4 is out apparently.
> > > > Trouble is, there is no ./dist.X/locale directory.
> > > We need to release an update. This bug is probably going to bite
> > > *most* users, as NLS is disabled by default.
> > Let's go for the update. I can do that (welcome pre5).
> > Glynn, could you check if we can use the pre4 branch? It should
> > be still in a good condition.
> We must to use the release branch, that's what it is for.
> Do you really think we should release pre5 that soon?
> We probably find even more release critical bugs...
I don't care whether we call it pre5 or pre4a or whatever. But we
*need* to supersede the current "pre4"; "make install" fails, which is
genuinely *critical*, IMHO.
Glynn Clements <glynn.clements at virgin.net>
