[GRASS5] Re: [bug #1052] (grass) [rsv].proj are crashing
Glynn Clements
glynn.clements at virgin.net
Thu May 23 11:29:01 EDT 2002
Markus Neteler wrote:
> Following fix cures the problem for env.c:
> cvs diff -u env.c
> RCS file: /grassrepository/grass/src/libes/gis/env.c,v
> retrieving revision 1.5
> diff -u -r1.5 env.c
> --- env.c 12 May 2002 12:04:45 -0000 1.5
> +++ env.c 23 May 2002 08:25:33 -0000
> @@ -177,13 +177,12 @@
> int n;
> for (n = 0; n < count; n++)
> - if (env[n].name && (strcmp(env[n].name, name)==0))
> + if (env[n].name && (strlen(name)!=0) && (strcmp(env[n].name, name)==0))
> free (env[n].name);
> env[n].name = 0;
> return 1;
> return 0;
> Objections to submit this fix?
This doesn't make any sense. What is the nature of the problem which
this is meant to fix?
Glynn Clements <glynn.clements at virgin.net>
