[GRASS5] Re: [bug #1052] (grass) [rsv].proj are crashing
Markus Neteler
neteler at itc.it
Thu May 23 12:10:00 EDT 2002
On Thu, May 23, 2002 at 04:29:01PM +0100, Glynn Clements wrote:
> Markus Neteler wrote:
> > Following fix cures the problem for env.c:
> > cvs diff -u env.c
> > RCS file: /grassrepository/grass/src/libes/gis/env.c,v
> > retrieving revision 1.5
> > diff -u -r1.5 env.c
> > --- env.c 12 May 2002 12:04:45 -0000 1.5
> > +++ env.c 23 May 2002 08:25:33 -0000
> > @@ -177,13 +177,12 @@
> > int n;
> > for (n = 0; n < count; n++)
> > - if (env[n].name && (strcmp(env[n].name, name)==0))
> > + if (env[n].name && (strlen(name)!=0) && (strcmp(env[n].name, name)==0))
> > free (env[n].name);
> > env[n].name = 0;
> > return 1;
> > return 0;
> > Objections to submit this fix?
> This doesn't make any sense. What is the nature of the problem which
> this is meant to fix?
Meanwhile the fix by Roger Miller is submitted to env.c.
Markus
