[GRASS5] [bug #1052] (grass) [rsv].proj are crashing
Morten Hulden
morten at ngb.se
Fri May 24 04:40:13 EDT 2002
On Fri, 24 May 2002, Eric G. Miller wrote:
> Now, if I can figure out why "1" is returned as the projection name for
> UTM...
Sounds like some artifact from old times is playing in here. UTM was one
of the few possible projection types in grass before proj was integrated
and the type 99 'other' was added. But even if proj can handle UTM, you
still find 'wrappers' here and there in the code that will give UTM
projection special treatment, i.e not passing it to proj at all, but
using the old code. Maybe the "1" is a response from some old stuff.
Morten Hulden
