[GRASS5] Re: r.mapcalc x() with no layer in expression
Dan Jacobson
jidanni at dman.ddts.net
Mon Nov 11 03:33:16 EST 2002
>>>>> "G" == Glynn Clements <glynn.clements at virgin.net> writes:
G> Dan Jacobson wrote:
>> Does the r.mapcalc man page and tutorial assume that one has the name
>> of an input map layer in some other part of the equation and thus
>> never mentions what happens if you don't, but still want to use x(),
>> y()?
>> Is this what one would be forced to do in that case?
>> (e.g. when making a layer with values being the distance from home:)
>> out=nantou.dist xc=235577 yc=2675353 ;\
>> r.mapcalc "${out?} = nantou - nantou + sqrt((x() - ${xc?})^2 + (y() - ${yc?})^2)"
>> [nantou - nantou: a noop just to get the layer nantou involved in the
>> expression.]
G> Why would you want to involve a map which wasn't actually used?
G> Note that the following will work:
G> r.mapcalc "${out?} = sqrt((x() - ${xc?})^2 + (y() - ${yc?})^2)"
OK, and indeed it does.
Well, it's not my fault that I didn't know that: the r.mapcalc man
page goes on and on about "raster map layers", never hinting that what
it really does is just march thru each cell[?] in the current region,
independently of any raster map, making calculations at each cell...
Maybe the man page should mention something like this near the top.
BTW: I see an "&"'s there instead of & , e.g.:
Some characters have special meaning to the
UNIX shell. These include, among others:
Also:
BUGS
Continuation lines must end with a and have NO trailing
End with a what? Can't tell from the manpage [5.0pre1].
http://jidanni.org/ Taiwan(04)25854780
