[GRASS5] Changes between 5.0.0 release and current release branch
Radim Blazek
blazek at itc.it
Thu Nov 28 03:26:39 EST 2002
On Thursday 28 November 2002 03:29 am, Eric G. Miller wrote:
> * Fixes interior boundary winding (shapefiles have exteriors clockwise,
> interiors counterclockwise) for areas with holes. AFAIK,
> Vect_get_area_points and Vect_get_isle_points always return clockwise
> polygons. So isle point orders are reversed. Isles will come up
> twice, once as interior and once as exterior. (If my understanding of
> these API's is incorrect, someone please let me know.)
I thought that direction for areas/isles is the same in grass as in shapefile
and Vect_get_isle_points returns counterclockwise vertices:
struct P_isle {
plus_t *lines; /* Boundary Lines (Negative means N2 to N1
counter-clockwise) */
int Vect_get_isle_points () {
if (Isle->lines[i] < 0) {
start = Points.n_points - 1; inc = -1 ; end = 1;
} else {
end = Points.n_points - 2; inc = 1 ; start = 0;
It is strange if shapefiles with reverted order of isles are correct.
Did you check it in ArcExplorer or other ESRI SW (AE runs on Linux)?
Radim
