[GRASS5] Changes between 5.0.0 release and current release branch
Eric G. Miller
egm2 at jps.net
Thu Nov 28 17:57:16 EST 2002
On Thu, Nov 28, 2002 at 03:50:20PM +0000, David D Gray wrote:
> But, shapes exported with the pre-changes v.out.shape are re-imported OK
> with v.in.shape, so the islands in the shape file must circulate the
> right way. That would suggest they are in the right order in the
> dig_plus file also. I'll check this with the new module.
Okay, you and Radim are apparently correct, so I'll revert the
direction.
"...the plural of anecdote is [not?] data." - attrib. to George Stigler
