[GRASS5] datum transforms...
Eric G. Miller
egm2 at jps.net
Fri Nov 29 20:33:46 EST 2002
After some prodding by Markus, I began looking at the datum transform
problem again. And, I see pj_transform() seems to already do what we
need (inverse project, datum shift, forward project) with any part
possibly being not applicable. Does anyone know of a good reason not to
use it?
After a little hacking, I have a modified s.proj that seems to work
well (not heavily tested).
Changes required:
pj_datums.c: s/ntv1 can.dat/ntv1_can.dat/
do_proj.c:
* LL<->LL is no longer a no-op.
* change all variations of pj_fwd and pj_inv to one call to
pj_transform
get_proj.c:
pj_get_kv()
* don't just return 1 on strncmp(proj_in,"Lat",3) == 0 ||
strcmp(info->proj,"ll") == 0
* when in_proj_keys->key[i] = "proj"
&& in_proj_keys->value[i] = "ll"
set buffa = "proj=latlong"
(libproj uses "latlong" or "longlat" vs. GRASS's "ll")
Before using pj_transform(), set the environment variable PROJ_LIB to
$GISBASE/etc/nad
#define GRIDDIR "/etc/nad"
static void set_proj_lib_env (void)
const char *gisbase = G_gisbase();
char *value = NULL;
size_t len = strlen(gisbase) * sizeof(GRIDDIR) + 1;
value = G_malloc (len);
sprintf (value, "%s%s", gisbase, GRIDDIR);
if (setenv ("PROJ_LIB", value, 1) == 0)
fprintf(stderr, "set PROJ_LIB='%s'\n", value);
else
fprintf(stderr, "failed to set PROJ_LIB='%s'\n", value);
free (value);
That was about all I needed to do to get s.proj2 working with
pj_transform (it took me the longest to figure out the space vs.
underscore in pj_datums.c was the cause of a failure...).
Since pj_transform operates on arrays and has height values (required),
a slightly different interface from do_proj might be appropriate (to
take advantage of transforming arrays in one "pass").
Anyway, comments?
"...the plural of anecdote is [not?] data." - attrib. to George Stigler
