[GRASS5] Re: grass 4.99+5.0.0pre4-1
Markus Neteler neteler at itc.it
Fri Nov 29 06:48:17 EST 2002
(cc grass5)
On Fri, Nov 29, 2002 at 10:52:46AM +0100, Federico Di Gregorio wrote:
> Scavenging the mail folder uncovered Markus Neteler's letter:
> because you're using the dreaded 'pre' and for dpkg version
> comparing algorithm, 5.0.0preX > 5.0.0. so it is not possible to
> automatically ugrade from 5.0.0preX to 5.0.0. it is common under
> debian to mangle a little bit versions to allow for automatic
> upgrades using apt.
... I see.
> > (4.99 is misleading)
> > and do you plan to package the stable release for the debian world?
> i am working on it. grass is a big package and i have to split documentation
> apart, make man pages available to default man command and a lot of
> other stuff. debian standards are quite high and i can't just build
> and release.
Perhaps backporting makes sense - please let us know about th
changes needed (but I won't promise to apply them all :-)
> btw, was the postgresql problem solved?
no idea... which one?
> ciao,
> federico
> Debian GNU/Linux Developer & Italian Press Contact        fog at debian.org
>   Those who do not study Lisp are doomed to reimplement it. Poorly.
>                                      -- from Karl M. Hegbloom .signature
Thanks,
 Markus
