[GRASS5] [bug #1460] (grass) critical import and display by r.in.arc within cignus OS
Eric G. Miller egm2 at jps.net
Fri Nov 29 15:16:07 EST 2002
On Fri, Nov 29, 2002 at 10:59:13AM +0100, Request Tracker wrote:
[snip]
> we launch command:
> GRASS> r.in.arc
> with default parameters.
> Sometimes, not always, alternatively for certain numbers of rows and columns
> we obtain a raster and we can also display.
> Some other times , with unknown logic, at displaying we have following system error:
> > WARNING: Fail of initial read of compressed file [layer100 in set1]
> > WARNING: unable to open raster map [layer100 in set1]
> > ERROR: Not able to open cellfile for [layer100]
This occurs when the row index can't be read (first message is from
src/libes/gis/format.c).  Are you sure r.in.arc successfully imported
these rasters (r.in.arc did not report errors)?
"...the plural of anecdote is [not?] data."  - attrib. to George Stigler
