[GRASS5] [bug #1332] (grass) r.in.gdal: import of arcinfo-asciigrid: northward shift by 1 cellsize
Request Tracker grass-bugs at intevation.de
Wed Oct 2 08:26:11 EDT 2002
this bug's URL: http://intevation.de/rt/webrt?serial_num=1332
Subject: r.in.gdal: import of arcinfo-asciigrid: northward shift by 1 cellsize
Platform: GNU/Linux/i386
grass obtained from: Trento Italy site
grass binary for platform: Downloaded precompiled Binaries
GRASS Version: GRASS 5.0.0 (August 2002)
Hi!
Import of arcinfo asciigrid data in a lat/lon-location using
r.in.gdal -o in=testdata out=testdata_rast
where the file "testdata" consists of
ncols 1
nrows 1
xllcenter 0.000000
yllcenter 0.000000
cellsize 1.000000
nodata_value -1.E20
42.0
yields a raster file with info (obtained from "r.info map=testdata_rast"):
|   Rows:         1
|   Columns:      1
|   Total Cells:  1
|        Projection: Latitude-Longitude (zone 0)
|            N:      1:30N    S:      0:30N   Res:     1
|            E:      0:30E    W:      0:30W   Res:     1
|   Range of data:    min =  42.000000 max = 42.000000
Number of rows, cells, longitude-info and range of data are correctly determined. However, the correct latitude information should instead be
  N:      0:30N    S:      0:30S   Res:     1
shouldn't it?
The erroneous (?) northward shifting by one cellsize seems to occur even with more complex arcinfo-asciigrid indata files and for other location types.
Is this an index problem in r.in.gdal for arcinfo-asciigrid data?
Help/comments appreciated, thanks in advance,
Thomas Klein
-------------------------------------------- Managed by Request Tracker
