[GRASS5] g51: v.surf.rst
Markus Neteler
neteler at itc.it
Fri Oct 4 09:52:57 EDT 2002
Hi all,
On Fri, Oct 04, 2002 at 09:32:31AM -0400, Helena Mitasova wrote:
> Radim,
> Jaro got the v.surf.rst running and results look good, but for more
> complete testing we need a little bit more info. On the grass51 web site
> you have a list of modules that need to be updated, do you also have a
> list of modules that are already done and that you are currently working
> on (so that we are not asking you too many questions?) So far I have found
> the following
> v.ascii v.category v.convert v.surf.rst v.build v.clean
> v.mapcalc
> and I am writing draft man pages for them (you may expect more questions from
> me).
To make things easier, is there a (simple) way to convert the XML output
from (e.g.)
v.category --interface-description
to HTML? Then writing pages would be somewhat more 'fun' as all this
parameter/flags formatting got automated. Probably this could be
added to the local Makefile, so that the HTML man pages consisted of
- part 1: autogenerated after (successful) compilation with
- part 2: a manually written description with is attached to part 1
So all the extra work of changing part 1 (params/flags) weren't required.
Just an incomplete idea,
Markus
