[GRASS5] g51: v.surf.rst
Helena Mitasova
hmitaso at unity.ncsu.edu
Fri Oct 4 09:32:31 EDT 2002
Radim,
Jaro got the v.surf.rst running and results look good, but for more complete
testing we need a little bit more info.
On the grass51 web site you have a list of modules that need to be updated, do
you also have a list
of modules that are already done and that you are currently working on (so that
we are not asking you too many questions?)
So far I have found the following
v.ascii v.category v.convert v.surf.rst v.build v.clean
v.mapcalc
and I am writing draft man pages for them (you may expect more questions from
me).
Now, what command should I use to find the names of zcol and scol? With
v.category report I get only field 1
which is category, how do I get the info about elevation? Do you plan to write
something like v.info that would
give a comprehensive information about what is in the vector file? (something
like s.info?)
Any chance for v.surf.rst to read directly shape files (not really important,
but if it is easy to do it would be great,
most of the data that we get are either nasty mixed-up CAD data or shape files).
It is still kind of adventure to use grass51 because there is so little info
about it
and we still haven't figured out how to call grass5 commands from grass51, but
we will get there eventually.
thank you,
Helena
