[GRASS5] Re: [GRASSweb-list]Cray Platform
Markus Neteler neteler at itc.it
Tue Oct 8 03:42:18 EDT 2002
On Mon, Oct 07, 2002 at 02:31:18PM -0600, Barry Oliphant wrote:
> Do you have any GRASS application running on Cray (PVP) platforms?
> Thank you,
> Barry Oliphant - Cray Service Manager
In general GRASS is not (yet) parallelized. But there are a few
options:
 - using LAPACK/parallel version (this required more changes in the GRASS
   libraries to replace the sequential versions)
 - There is one application with MPI architecture available:
   s.surf.idw.mpi2
(see url's at: http://grass.itc.it/grass5/index.html#cluster )
Potentially also s.surf.rst, s.vol.rst (both interpolation tools) could be
parallelized as well as other GRASS applications which already use
spatial segmentation (r.cost etc.).
Kind regards
  Markus Neteler
