[GRASS5] [bug #1339] (grass) cannot find i.gray.scale
Markus Neteler
neteler at itc.it
Tue Oct 8 03:45:27 EDT 2002
On Tue, Oct 08, 2002 at 07:43:51AM +0200, Request Tracker wrote:
> this bug's URL: http://intevation.de/rt/webrt?serial_num=1339
> Subject: cannot find i.gray.scale
> Platform: GNU/Linux/i386
> grass obtained from: CVS
> grass binary for platform: Downloaded precompiled Binaries
> GRASS Version: 5.0August2002
> Dear sir,
> I try to use i.gray.scale in GRASS 5.0 released August 2002. It cannot found that command.
> Please advice me.
> Thank you
> Thongchai Phothong
To reduce the number of identical modules this command was removed from
GRASS. The identical function is:
r.colors map=name col=grey.eq
Markus
