[GRASS5] grass5.0 and 5.1 merge question
Bernhard Reiter bernhard at intevation.de
Thu Oct 10 09:15:36 EDT 2002
Helena,
it is clear that there will be no general/automatic merge of the two
development lines grass 5.0 and grass 5.1 .
Grass is a huge project, we cannot completely avoid
that we need to port or backport in some areas where development is fast.
There is no general rule to decide on where to start working
with new features. It will be a case by case decision.
Here are at least some arguments:
If you need the features fast and for production and other people
this are arguments to take the 5.0 as a basis.
However you have to be prepared to to port it to 5.1 later.
If you find that you need features from GRASS that will only be
present in 5.1 this would be an argument to base it on 5.1
and help to organise to make 5.2 happen.
On Thu, Oct 10, 2002 at 08:51:26AM -0400, Helena Mitasova wrote:
> Markus Neteler wrote:
> > there is probably a little confusion.
> No there is not - we have nviz in 5.1 that supports 3D vectors and
> then we have nviz5.0 with Bob Covill's improvements and those two
> need to be merged before more work is done, in particular on
> integrating g3d.
> It appears to me that merging grass5.1 and grass5.0 should be a no.
> 1 priority right now before more work is done on each separately.
> (e.g. if I want to do some enhancements to RST should I do it to
> s.surf.rst5.0 or v.surf.rst5.1?)
> I understand, that Radim does not want the merge before he has
> more of the vector capabilities done, but while the GRASS5.0 is
> being cleaned up, he may as well have enough done on the vector
> side.
> The milestones are set at http://grass.itc.it/grass51/index.html -
> maybe they should be revised and updated (I think there are few
> items even in phase 2 that are already done).
> Glynn, Bernhard, do you have any advice on how to proceed with this?
> It was already discussed but it ended up with no clear solution.
> just a good advice on how and where to develop new capabilities in
> terms of grass5.1 and grass5.0exp would be helpful,
> > Alfonso Vitti <alfonso.vitti at ing.unitn.it>
> > Is working on G3D, while Radim is working on GRASS 5.1 3D vectors.
> > On Thu, Oct 10, 2002 at 12:46:46PM +0200, Peter Paudits wrote:
> > > As you already know, Tomas Paudits will start to update nviz
> > > too. He wants to append 3D volume visualization features
> > > (isosurfaces, walls, boxes, profiles etc.) into current
> > > version of nviz. He decided to use actual version of nviz in
> > > experimental grass5.1 sources from official grass5.1 page for
> > > future work. Is it correct?  Radim, do you currently work on
> > > nviz development? Where we can get the latest version of this
> > > with latest status of 3D vector features?
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20021010/06f50f0e/attachment.bin
